M4250-26G4XF-PoE+ (GSM4230PX)
24x1G PoE+ 480W 2x1G and 4xSFP+ Managed Switch
Switching engineered for 1G AV over IP with rear-facing ports ensuring a clean integration in AV racks. Pre-configured for out of the box functionality!
![M4250 ProAv Powerful Av Switches](/ca-en/media/m4250-proav-powerful-av-switches-mobile_tcm186-140004.jpg)
![M4250 ProAv Powerful Av Switches](/ca-en/media/m4250-proav-powerful-av-switches_tcm186-140003.jpg)
POWERFUL AV SWITCHES
MADE SIMPLE
![M4250 AV OVER IP SIMPLIFIED](/ca-en/media/m4250-proav-over-ip-simplified_tcm186-140006.jpg)
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
![](/ca-en/media/m4250-pro-av-dt-3-mb_tcm186-139373.jpg)
![](/ca-en/media/m4250-pro-av-dt-3_tcm186-139379.jpg)
FAST, EASY
CONFIGURATION
FOR AV PROS
![](/ca-en/media/m4250-pro-av-dt-4-mb_tcm186-139372.jpg)
![](/ca-en/media/m4250-pro-av-dt-4_tcm186-139378.jpg)
FOCUS ON THE EVENT
NOT FAN NOISE
![M4250 DESIGNED FOR AV OVER IP RIGHT OUT OF THE BOX](/ca-en/media/m4250-right-out-of-the-box_tcm186-140013.jpg)
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
![M4250 - REFINED DESIGN PROVIDES MOUNTING FLEXIBILITY](/ca-en/media/m4250-pro-av-6-mb_tcm186-139929.jpg)
![M4250 - REFINED DESIGN PROVIDES MOUNTING FLEXIBILITY](/ca-en/media/m4250-pro-av-6_tcm186-139921.jpg)
REFINED DESIGN
PROVIDES MOUNTING
FLEXIBILITY
COMPARE M4250 SERIES SWITCHES
![]() GSM4230PX |
![]() GSM4210PD |
![]() GSM4210PX |
![]() GSM4212P |
![]() GSM4212PX |
![]() GSM4212UX |
![]() MSM4214X |
![]() XSM4216F |
![]() GSM4230P |
![]() GSM4230UP |
![]() GSM4248P |
![]() GSM4248PX |
![]() GSM4248UX |
# Total Ports |
# Total Ports 30 |
# Total Ports 10 |
# Total Ports 10 |
# Total Ports 12 |
# Total Ports 12 |
# Total Ports 12 |
# Total Ports 14 |
# Total Ports 16 |
# Total Ports 30 |
# Total Ports 30 |
# Total Ports 48 |
# Total Ports 48 |
# Total Ports 48 |
Port Types |
Port Types 26x 1G,4x SFP+ |
Port Types 9x 1G, 1x SFP |
Port Types 8x 1G, 2x SFP+ |
Port Types 10x 1G, 2x SFP |
Port Types 10x 1G, 2x SFP+ |
Port Types 12x 2.5G, 2x SFP+ |
Port Types 16x 1G/10G Fiber SFP+ |
Port Types 26x 1G, 4x SFP |
Port Types 40x 1G, 8x SFP |
Port Types 40x 1G, 8x SFP+ |
Total PoE Budget |
Total PoE Budget 480W |
Total PoE Budget 110W |
Total PoE Budget 220W |
Total PoE Budget 125W |
Total PoE Budget 240W |
Total PoE Budget 720W |
Total PoE Budget - |
Total PoE Budget 300W |
Total PoE Budget 1,440W |
Total PoE Budget 960W |
Total PoE Budget 2,880W |
# PoE+ Ports |
# PoE+ Ports 24 |
# PoE+ Ports 8 |
# PoE+ Ports 8 |
# PoE+ Ports 8 |
# PoE+ Ports 8 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports - |
# PoE+ Ports 40 |
# PoE+ Ports 40 |
# PoE+ Ports - |
# PoE++ Ports |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 8 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 24 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 40 |
Rack Mount |
Rack Mount 1U |
Rack Mount Desktop |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 2U |
Form Factor WxHxD (mm) |
Form Factor WxHxD (mm) 440 x 43.2 x 400 |
Form Factor WxHxD (mm) 210 x 40 x 140 |
Form Factor WxHxD (mm) 440 x 43.2 x 200 |
Form Factor WxHxD (mm) 440 x 43.2 x 257 |
Form Factor WxHxD (mm) 440 x 43.2 x 100 |
Form Factor WxHxD (mm) 440 x 86.4 x 350 |
![](/ca-en/media/m4250-pro-av-dt-7-mb_tcm186-139367.jpg)
![](/ca-en/media/m4250-pro-av-dt-7_tcm186-139366.jpg)
MAXIMIZE
PERFORMANCE
WITH NETGEAR
ACCESS POINTS
Enable powerful, reliable WiFi at your location with WAX600 Series PoE access points.
![](/ca-en/media/m4250-pro-av-dt-8-mb_tcm186-139370.jpg)
![](/ca-en/media/m4250-pro-av-dt-8_tcm186-139376.jpg)
PRO AV
RESOURCES
![m4250-pro-av-10-mb](/ca-en/media/m4250-pro-av-10-mb_tcm186-140580.jpg)
![m4250-pro-av-10](/ca-en/media/m4250-pro-av-10_tcm186-140579.jpg)
![Tech Specs - GSM4230PX Front](/ca-en/media/gsm4230px-front_tcm186-140068.jpg)
![Tech Specs - GSM4230PX Back](/ca-en/media/gsm4230px-back_tcm186-140067.jpg)
- Dimensions (WxDxH) : 440 x 400 x 43.2 mm
- Weight : 5.45 kg (12.02lb)
- Primary Port Speed : 1 Gigabit
- Number of Ports : 30 (24x 1G PoE+, 2x 1G, 4x SFP+)
- PoE Ports / Budget : 24 PoE+ (30W/port), 480W Budget
- IGMP Support : Enhanced (NETGEAR IGMP Plus™)
- Jumbo Frame Support : Yes, up to 12kb
- AVB Support : Yes. Electronic license required, activation key sent via email (AVB4230PX-10000S)
- Acoustics : Fanless or 42dB@25ºC
- TBD Power Consumption : With PoE: 614W/2096.2Btu/hr
- Without PoE: 46.8W/159.78Btu/hr
- Standby without any port connection: 33.9W/115.73Btu/hr
Third party support : Domotz
- Warranty: This product is backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty . This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
- Support : Phone and chat technical support provided for 90 days from purchase date.
- What's in the Box : M4250-26G4XF-PoE+ (GSM4230PX)
- Power cord(s)
- Console USB Type-C and RJ45-DB9 cables
- Rack-mounting standard brackets
- Longer brackets for recessed mounting
- Rubber footpads for tabletop installation
- Installation guide
