M4350-44M4X4V Fully Managed Switch (MSM4352)
44x2.5G, 4x10G/Multi-gig PoE++ (194W base, up to 3,314W) and 4xSFP28 25G (MSM4352) Managed Switch
- 44 2.5G and 4 10G/Multi-gig PoE++ ports with 4 25GBASE-X SFP28 uplinks
- 550W internal power supply providing 194W of PoE budget
- 2 slots for modular power supplies (1+1 redundancy and/or EPS share)
- Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
- The PoE budget can reach 3,314W, the redundant PoE budget can reach 1,794W
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
- TAA compliant SKU is available. Contact your sales representative
![M4350 Power and Throughput](/ca-en/media/m4350-power-and-throughput-mobile_tcm186-150409.webp)
![m4350 Power And Throughput](/ca-en/media/m4350-power-and-throughput_tcm186-150410.webp)
POWER AND
THROUGHPUT
![M4350 AV OVER IP SIMPLIFIED](/ca-en/media/m4350-av-over-ip-simplified-mobile_tcm186-150412.jpg)
![M4350 AV OVER IP SIMPLIFIED](/ca-en/media/m4350-av-over-ip-simplified_tcm186-150411.webp)
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
![M4350 FAST, EASY CONFIGURATION](/ca-en/media/M4350-fast-easy-configuration-mobile_tcm186-150413.webp)
![M4350 FAST, EASY CONFIGURATION](/ca-en/media/M4350-fast-easy-configuration_tcm186-150414.webp)
FAST, EASY
CONFIGURATION
FOR AV PROS
![](/ca-en/media/m4250-pro-av-dt-4-mb_tcm186-139372.jpg)
![](/ca-en/media/m4250-pro-av-dt-4_tcm186-139378.jpg)
FOCUS ON THE EVENT
NOT FAN NOISE
![](/ca-en/media/m4250-pro-av-dt-5-mb_tcm186-139371.jpg)
![](/ca-en/media/m4250-pro-av-dt-5_tcm186-139377.jpg)
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
![]() MSM4352 |
![]() GSM4328 |
![]() GSM4352 |
![]() XSM4316 |
![]() XSM4324 |
![]() XSM4328CV |
![]() XSM4328FV |
![]() XSM4340CV |
![]() XSM4340V |
![]() XSM4340FV |
![]() VSM4320C |
![]() XSM4344C |
# Total Ports |
# Total Ports 52 |
# Total Ports 28 |
# Total Ports 52 |
# Total Ports 16 |
# Total Ports 24 |
# Total Ports 28 |
# Total Ports 28 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 20 |
# Total Ports 44 |
Port Types |
Port Types 44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G, 4x SFP+ |
Port Types 48x 1G, 4x SFP+ |
Port Types 8x 1G/2.5G/5G/10G, 8x SFP+ |
Port Types 12x 1G/2.5G/5G/10G, 12x SFP+ |
Port Types 24x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x SFP+, 4x SFP28 (25G) |
Port Types 36x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G) |
Port Types 32x SFP+, 8x SFP28 (25G) |
Port Types 16x SFP28 (25G), 4x QSFP28 (100G) |
Port Types 40x 1G/2.5G/5G/10G, 4x QSFP28 (100G) |
Total PoE Budget |
Total PoE Budget 194W -> 3,314W |
Total PoE Budget 648W –> 720W |
Total PoE Budget 236W -> 1,440W |
Total PoE Budget - |
Total PoE Budget 576W -> 720W |
Total PoE Budget 280W -> 1,760W |
Total PoE Budget 290W -> 1,770W |
Total PoE Budget 196W -> 1,676W |
# PoE+ Ports |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports 48 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE++ Ports |
# PoE++ Ports 48 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 36 |
# PoE++ Ports 24 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 40 |
Rack Mount |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
FORM FACTOR W X H x D (MM) |
FORM FACTOR W X H x D (MM) 440 x 400 x 43.2 |
FORM FACTOR W X H x D (MM) 220 x 400 x 43.2 |
![MSM4352 MAXIMIZE PERFORMANCE](/ca-en/media/M4350_Max_performance_MSM4352_mobile_tcm186-150717.jpg)
![MSM4352 MAXIMIZE PERFORMANCE](/ca-en/media/M4350_Max_performance_MSM4352_tcm186-150716.webp)
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
![](/ca-en/media/m4250-pro-av-dt-8-mb_tcm186-139370.jpg)
![](/ca-en/media/m4250-pro-av-dt-8_tcm186-139376.jpg)
PRO AV
RESOURCES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
M4350-MSM4352 Technical Specifications
![GSM4352_Tech-Specs-Front](/ca-en/media/GSM4352_Tech-Specs-desktopv1_tcm186-150691.jpg)
![GSM4352_Tech-Specs-Back](/ca-en/media/GSM4352_Tech-Specs-mobilev1_tcm186-150692.jpg)
Product Specifications
M4350-44M4X4V (MSM4352)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight7.34kg (16.18lb)
Primary Port Speed2.5 Gigabit
Number of Ports52 (44 x 2.5G PoE++, 4 x 10G/Multi-Gig PoE++, 4 x 25G SFP28)
PoE Ports / Budget48 PoE++ (90W/port), 194W Base, up to 3,314W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 34dB@25ºC
Power Consumption
With PoE: 351.5W/1198.62Btu/hr
Without PoE: 133.5W/419.19Btu/hr
Standby without any port connection: 56.5W/177.41Btu/hr
PSU Compatible Models
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
This product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
Pro AV Information
M4350-44M4X4V Support
AV Resource Center
