M4350-16V4C Fully Managed Switch (VSM4320C)
16xSFP28 25G and 4xQSFP28 100G Managed Switch
- 16 25GBASE-X SFP28 ports with 4 100GBASE-X QSFP28 uplinks
- 420W internal power supply
- 1 slot for modular power supply (1+1 redundancy)
- Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- Supports SMPTE ST2110 IP broadcast protocol
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
- TAA compliant SKU is available. Contact your sales representative
POWER AND
THROUGHPUT
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
VSM4320C |
GSM4328 |
GSM4352 |
MSM4352 |
XSM4316 |
XSM4324 |
XSM4328CV |
XSM4328FV |
XSM4340CV |
XSM4340V |
XSM4340FV |
XSM4344C |
# Total Ports |
# Total Ports 20 |
# Total Ports 28 |
# Total Ports 52 |
# Total Ports 52 |
# Total Ports 16 |
# Total Ports 24 |
# Total Ports 28 |
# Total Ports 28 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 44 |
Port Types |
Port Types 16x SFP28 (25G), 4x QSFP28 (100G) |
Port Types 24x 1G, 4x SFP+ |
Port Types 48x 1G, 4x SFP+ |
Port Types 44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 8x 1G/2.5G/5G/10G, 8x SFP+ |
Port Types 12x 1G/2.5G/5G/10G, 12x SFP+ |
Port Types 24x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x SFP+, 4x SFP28 (25G) |
Port Types 36x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G) |
Port Types 32x SFP+, 8x SFP28 (25G) |
Port Types 40x 1G/2.5G/5G/10G, 4x QSFP28 (100G) |
Total PoE Budget |
Total PoE Budget - |
Total PoE Budget 648W –> 720W |
Total PoE Budget 236W -> 1,440W |
Total PoE Budget 194W -> 3,314W |
Total PoE Budget 576W -> 720W |
Total PoE Budget 280W -> 1,760W |
Total PoE Budget 290W -> 1,770W |
Total PoE Budget 196W -> 1,676W |
# PoE+ Ports |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports 48 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE++ Ports |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 48 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 36 |
# PoE++ Ports 24 |
# PoE++ Ports - |
# PoE++ Ports 40 |
Rack Mount |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
FORM FACTOR W X H x D (MM) |
FORM FACTOR W X H x D (MM) 440 x 400 x 43.2 |
FORM FACTOR W X H x D (MM) 220 x 400 x 43.2 |
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
PRO AV
RESOURCES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
M4350-VSM4320C Technical Specifications
Product Specifications
M4350-16V4C (VSM4320C)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight7.15kg (15.77lb)
Primary Port Speed25 Gigabit
Number of Ports20 (16 x 25G SFP28, 4 x 100G QSFP28)
PoE Ports / BudgetN/A
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 33.4dB@25ºC
Power Consumption
143.4W/450.28Btu/hr
Standby without any port connection: 60.4W/189.66Btu/hr
PSU Compatible Models
APS600Wv3
APS1200Wv2
APS2000Wv2
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
This product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
Pro AV Information
M4350-16V4C Support
AV Resource Center
