  • 24 10GBASE-X SFP+ ports with 4 25GBASE-X SFP28 uplinks
  • 240W internal power supply
  • 1 slot for modular power supply (1+1 redundancy)
  • Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
  • NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
  • NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
  • Lifetime Next Business Day Hardware Replacement
XSM4328FV XSM4328FV-100NES XSM4328FV-100NES
M4350-24F4V Fully Managed Switch (XSM4328FV) armor
24xSFP+ and 4xSFP28 25G Managed Switch armor
We're always here to help
Want a custom configuration?
Need to check compatibility?
Ready for a quote?
Our experts are available via online chat, phone, or email.
Join Waitlist
Successfully registered.
M4350 Power and Throughput m4350 Power And Throughput
POWER AND
THROUGHPUT
M4350 AV OVER IP SIMPLIFIED M4350 AV OVER IP SIMPLIFIED
  • Groundbreaking AV GUI
  • Multicast in an Instant
  • Sleek, Quiet Design
  • Automatic Configuration
M4350 FAST, EASY CONFIGURATION M4350 FAST, EASY CONFIGURATION
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
SWITCHES_M4350
XSM4328FV
SWITCHES_M4350
GSM4328
SWITCHES_M4350
GSM4352
M4350 MSM4310
MSM4310
SWITCHES_M4350
MSM4332
msm4328f-front-right
MSM4328F
SWITCHES_M4350
XSM4344FC
SWITCHES_M4350
MSM4352
SWITCHES_M4350
XSM4316
SWITCHES_M4350
XSM4324
SWITCHES_M4350
XSM4328CV
SWITCHES_M4350
XSM4340CV
SWITCHES_M4350
XSM4340V
SWITCHES_M4350
XSM4340FV
SWITCHES_M4350
VSM4320C
SWITCHES_M4350
XSM4344C
# Total Ports
# Total Ports
28
# Total Ports
28
# Total Ports
52
# Total Ports
10
# Total Ports
32
# Total Ports
28
# Total Ports
44
# Total Ports
52
# Total Ports
16
# Total Ports
24
# Total Ports
28
# Total Ports
40
# Total Ports
40
# Total Ports
40
# Total Ports
20
# Total Ports
44
Port Types
Port Types
24x SFP+, 4x SFP28 (25G)
Port Types
24x 1G, 4x SFP+
Port Types
48x 1G, 4x SFP+
Port Types
8x2.5G, 2x25G SFP28
Port Types
24x2.5G, 4x10G, 4x25G SFP28
Port Types
24xSFP+, 4x10GBASE-T/SFP+
Port Types
40x10G SFP+, 4x100G QSFP28
Port Types
44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
8x 1G/2.5G/5G/10G, 8x SFP+
Port Types
12x 1G/2.5G/5G/10G, 12x SFP+
Port Types
24x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
36x 1G/2.5G/5G/10G, 4x SFP28 (25G)
Port Types
24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G)
Port Types
32x SFP+, 8x SFP28 (25G)
Port Types
16x SFP28 (25G), 4x QSFP28 (100G)
Port Types
40x 1G/2.5G/5G/10G, 4x QSFP28 (100G)
Total PoE Budget
Total PoE Budget
Total PoE Budget
648W –> 720W
Total PoE Budget
236W -> 1,440W
Total PoE Budget
120W -> 550W
Total PoE Budget
510W -> 2,520W
Total PoE Budget
Total PoE Budget
Total PoE Budget
194W -> 3,314W
Total PoE Budget
Total PoE Budget
Total PoE Budget
576W -> 720W
Total PoE Budget
280W -> 1,760W
Total PoE Budget
290W -> 1,770W
Total PoE Budget
Total PoE Budget
Total PoE Budget
196W -> 1,676W
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
48
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
8
# PoE++ Ports
24
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
48
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
36
# PoE++ Ports
24
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
40
Rack Mount
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
FORM FACTOR W X H x D (MM)
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
220x300x43.2
440 x 400 x 43.2
440 x 400 x 43.2
440x400x43.2
440 x 400 x 43.2
220 x 400 x 43.2
220 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
440 x 400 x 43.2
XSM4328FV MAXIMIZE PERFORMANCE XSM4328FV MAXIMIZE PERFORMANCE
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
PRO AV
RESOURCES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES
M4350 SWITCH SERIES
M4500 SWITCH SERIES
USE CASE
USE CASE
Access/Edge
USE CASE
Core/Access/Edge
USE CASE
Core/Access/Edge
SWITCH STACKING
SWITCH STACKING
No
SWITCH STACKING
Yes
SWITCH STACKING
No (MLAG)
PoE CAPABLE
PoE CAPABLE
Yes
PoE CAPABLE
Yes
PoE CAPABLE
No
PORT SPEEDS
PORT SPEEDS
1, 2.5, 10Gbps
PORT SPEEDS
1, 2.5, 10, 25, 100Gbps
PORT SPEEDS
1, 10, 25, 100Gbps
AVB SUPPORT
AVB SUPPORT
Yes*
AVB SUPPORT
Yes
AVB SUPPORT
No
AV WEB UI / AV TEMPLATES
Yes
Yes
No
AV DESIGN
(FRONT LED'S & REAR CABLING)
AV DESIGN
Yes
AV DESIGN
No
AV DESIGN
No
M4350-XSM4328FV Technical Specifications
XSM4328FV_Tech-Specs-Front XSM4328FV_Tech-Specs-Back
Product Specifications
  • M4350-24F4V (XSM4328FV)
    1
  • Power cord(s)
    1
  • Console USB Type-C cable
    1
  • Rack-mounting standard bracket set
    1
  • Set of longer brackets for recessed mounting
    1
  • Rubber footpads for tabletop installation
    4
  • Installation guide
    1
  • Width
    440mm
  • Depth
    400mm
  • Height
    43.2mm
  • Weight
    6.25kg (13.78lb)
  • Primary Port Speed
    10 Gigabit
  • Number of Ports
    28 (24 x 10G SFP+, 4 x 25G SFP28)
  • PoE Ports / Budget
    N/A
  • IGMP Support
    Enhanced (NETGEAR IGMP Plus™)
  • Jumbo Frame Support
    Yes, up to 12kb
  • AVB Support
    Yes, included
  • Acoustics
    Quiet Mode 34.2dB@25ºC
  • Power Consumption
    119.3W/374.6Btu/hr
    Standby without any port connection: 45.2W/141.93Btu/hr
  • PSU Compatible Models
    APS350Wv1
    APS600Wv2
    APS920Wv1
    APS2000Wv1
  • NETGEAR Engage Controller
    Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
  • This product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
