Gigabit Unmanaged Switch Series (GS105)
5-Port Gigabit Ethernet Unmanaged Switch
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
NETGEAR PoE Switches
ETHERNET PORT CONFIGURATION
5 Gigabit ports
PLUG-AND-PLAY
FULL PERFORMANCE
Non-blocking switching architecture for maximum throughput at wire speedReliable Performance
Superior network performance at non-blocking rate delivers true Gigabit speed with no compromise
High Quality
Durable metal case and long product lifeEnergy Efficient
Energy Efficient Ethernet (IEEE 802.3az) standard, which reduces energy consumption when there is light traffic on an active port or when there is no link or no activity detectedSILENT OPERATION
ENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate
Metal Case
Durable and Rugged
VERSATILE MOUNTING OPTIONS
Supports desktop or wall placement, and includes wall mounting kit in the boxSTANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDsTechnical Specifications
![GS105_tech_specs_image_1](/ca-en/media/GS105_tech_specs_image_1_tcm186-100419.png)
![GS105_tech_specs_image_2](/ca-en/media/GS105_tech_specs_image_2_tcm186-100396.png)
- Dimensions (WxDxH) @mm : 94 mm x 100 mm x 27 mm
- Weight (kg) : 0.261 kg
- Speed : 10/100/1000Mbps Gigibit Ethernet
- Number of Ports : 5
- PoE ports : n/a
- Total PoE Budget : n/a
- Loop Detection : n/a
- Short cable power saving : n/a
- Energy Efficient Ethernet Support (IEEE 802.3az) : Yes
- Jumbo Frame Support : Yes
- Queue WRR Ratio : 1:2:4:8
- MAC Table Size : 2K
- Packet buffer size : 128KB
- IEEE 802.1p QoS : Yes
- Max Power Consumption : 2.7W
- Operating Temperature : 50°C
- MTBF (hours) : 3,197,945 hours
- FCC Class : B
- Warranty : This product is backed by a NETGEAR Limited Lifetime Hardware Warranty.
- Support
