Gigabit 16-port Unmanaged Switch (GS116)
16-Port Gigabit Ethernet Unmanaged Switch
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
PLUG & PLAY
Simple setup with no software or configuration needed
FLEXIBLE MOUNTING
Mount on rack, desktop, or wall
SMALL SIZE, METAL CASE, AND SILENT OPERATION
Durable quality, space saver, and quietness for peace of mind
LIFETIME LIMITED WARRANTY & NEXT BUSINESS DAY REPLACEMENT
NETGEAR has your back to ensure your network is up and running
STURDY METAL CASE, DESKTOP/RACKMOUNT FORM FACTOR WITH QUIET FANS
Can be placed on desk or on mounted rack and will operate quietly with assured durabilityChoice of Fast Ethernet and Gigabit Ethernet connectivity
Energy-efficient technology for power savings
Auto-MDI/MDIX eliminates the need for crossover cables
Auto-negotiation for automatic connection at the highest common speed between switch and an end device
Desktop or rackmountable
The NETGEAR Gigabit Unmanaged Switch series helps businesses cost-effectively expand their network to Gigabit speeds and higher port counts
Unmanaged Gigabit switches come in a wide range of models including desktop, wall-mount and rackmount form factors and 5 to 24 port configurations
Energy efficient, built to last, and rigorously tested to provide the reliability businesses need
802.1p traffic prioritization and jumbo frame support allow for seamless integration with more sophisticated networks
![GS116_Tech Specs Image 1](/ca-en/media/GS116_Tech%20Specs%20Image%201_tcm186-100368.png)
![GS116_Tech Specs Image 2](/ca-en/media/GS116_Tech%20Specs%20Image%202_tcm186-100431.png)
- Dimensions (WxDxH) @mm : 285 x 102 x 27 mm
- Weight (kg) : 0.896
- Speed : 10/100/1000Mbps Gigibit Ethernet
- Number of Ports : 16
- PoE ports : N/A
- Total PoE Budget : N/A
- Loop Detection : N/A
- Short cable power saving : N/A
- Energy Efficient Ethernet Support (IEEE 802.3az) : Yes
- Jumbo Frame Support : 9KB
- Queue WRR Ratio : 1:2:4:8
- MAC Table Size : 8K
- Packet buffer size : 2MB
- IEEE 802.1p QoS : Yes
- Max Power Consumption : 9.5W
- Operating Temperature : 0 to 50° C
- MTBF (hours) : 554,582
- FCC Class : A
- Support
