![](/hk-en/media/PoE_Main_mobile_tcm199-148228.jpg)
![](/hk-en/media/PoE_Main_desktop_tcm199-148227.jpg)
What is PoE? - Power up your Business
How does PoE Work?
Deploy PoE technology for WiFi Access Points, IP cameras, LED Lights, and more.
What is Power over Ethernet (PoE)
Power over Ethernet (PoE) provides power and network connectivity for PoE-powered devices over a single network cable. It's a 2-in-1 solution, so you don’t have the restriction that your devices are close to a power outlet. PoE devices range from wireless access points, IP cameras, VoIP phones, PoE LED lighting, PoE speakers to IoT doorbells and other IoT devices. These devices are powered and in some cases manageable by our PoE switches.
![](/hk-en/media/Without%20PoE_tcm199-114960.png)
Without PoE
![](/hk-en/media/PoE-WithPoE_tcm199-114959.jpg)
With PoE
One Ethernet cable provides power AND connectivity
LOWER INFRASTRUCTURE AND INSTALLATION COSTS
Fewer, separate power adapters are needed and only one cable run is required rather than two.
CENTRALIZED CONTROL
Manage power to devices from a centralized switch. Power down/up devices as required for energy and cost savings.
NO NEED FOR ELECTRICIANS
Uses existing IT networking infrastructure.
EXTENDS WIRED AND WIRELESS NETWORK REACH
Not limited to fixed power outlet placements.
OVERCOMES HARD TO WIRE ENVIRONMENTS
Including old or ‘protected’ buildings.
RELIABILITY
Redundant Power Supply (RPS) backup options helps keep devices running even in the event of a power outage. Important for business critical services, such as IP Telephony based Call Centers.
PoE (802.3af)
Type 1:
The original PoE standard provides 15.4W of power to the Ethernet port to be sent = 12.95W of delivered power at 100M distance from the switch.
PoE+(802.3at)
Type 2:
PoE+ effectively doubles the PoE power to the device by providing 30W of power to the Ethernet port to be sent = 25.5W of delivered power at 100M distance from the switch.
PoE++(802.3bt)
Type 3 and 4:
PoE++ (bt) now effectively doubles the PoE+ power to the device by providing 60W (Type 3) or 90W (Type 4) of power
PoE Class Chart
MINIMUM POWER LEVELS THE PSE NEEDS TO PROVIDE |
MAX POWER AVAILABLE TO THE PD |
POWERED DEVICES (PD) |
1 |
1 4.0W |
1 0.44W-3.84W |
1 IP Phone |
2 |
2 7.0W |
2 3.84W-6.49W |
2 IP Camera |
3 (PoE) |
3 (PoE) 15.4W |
3 (PoE) 6.49W-12.95W |
3 (PoE) Single Band Wireless Access Point, Video Phone |
4 (PoE+) |
4 (PoE+) 30.0W |
4 (PoE+) 12.95W-25.5W |
4 (PoE+) PTZ IP Camera, Dual Band 11ac Wireless AP |
5/6 (PoE++) |
5/6 (PoE++) 60.0W |
5/6 (PoE++) 25.5W-51W |
5/6 (PoE++) Building lighting systems, next gen VDI clients |
7/8 (PoE++) |
7/8 (PoE++) 90.0W |
7/8 (PoE++) 25.5W-71W |
7/8 (PoE++) Building lighting systems, next gen VDI clients |
![](/hk-en/media/PoE%20Surveillance%20Image-1_tcm199-114957.jpg)
![](/hk-en/media/PoE%20Netgear%20Advantage_tcm199-116202.jpg)
![](/hk-en/media/PoE%20Innovation%20Image_tcm199-116201.jpg)
Devices
NETGEAR has the largest portfolio of PoE switches for SMBs with over 50 different models. Advance your business with cost-effective and easy-to-install PoE devices.
![OG Image](/hk-en/media/gs308p_tcm199-148461.jpg)
