Switching engineered for 1G AV over IP with rear-facing ports ensuring a clean integration in AV racks. Pre-configured for out of the box functionality! GSM4230PX GSM4230PX-100NAS GSM4230PX-100NAS
M4250-26G4XF-PoE+ (GSM4230PX) armor
24x1G PoE+ 480W 2x1G and 4xSFP+ Managed Switch armor
We're always here to help
Want a custom configuration?
Need to check compatibility?
Ready for a quote?
Our experts are available via online chat, phone, or email.
Join Waitlist
Successfully registered.
M4250 ProAv Powerful Av Switches M4250 ProAv Powerful Av Switches
POWERFUL AV SWITCHES
MADE SIMPLE
M4250 AV OVER IP SIMPLIFIED
  • Groundbreaking AV GUI
  • Multicast in an Instant
  • Sleek, Quiet Design
  • Automatic Configuration
FAST, EASY
CONFIGURATION
FOR AV PROS
FOCUS ON THE EVENT
NOT FAN NOISE
M4250 DESIGNED FOR AV OVER IP RIGHT OUT OF THE BOX
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
M4250 - REFINED DESIGN PROVIDES MOUNTING FLEXIBILITY M4250 - REFINED DESIGN PROVIDES MOUNTING FLEXIBILITY
REFINED DESIGN
PROVIDES MOUNTING
FLEXIBILITY
COMPARE M4250 SERIES SWITCHES
Everest_Hero-Image_GSM4230PX
GSM4230PX
Hero-Image-GSM4210PD
GSM4210PD
Everest_GSM4210PX_PDP_32_Hero-Image
GSM4210PX
HeroImage
GSM4212P
HeroImage
GSM4212PX
HeroImage
GSM4212UX
HeroImage
MSM4214X
Hero Image
XSM4216F
GSM4230P
Everest-Hero-Image-GSM4230UP
GSM4230UP
Everest_Hero-Image_GSM4248P
GSM4248P
Everest_Hero-Image_GSM4248PX
GSM4248PX
Everest_Hero-Image_GSM4248UX
GSM4248UX
# Total Ports
# Total Ports
30
# Total Ports
10
# Total Ports
10
# Total Ports
12
# Total Ports
12
# Total Ports
12
# Total Ports
14
# Total Ports
16
# Total Ports
30
# Total Ports
30
# Total Ports
48
# Total Ports
48
# Total Ports
48
Port Types
Port Types
26x 1G,4x SFP+
Port Types
9x 1G, 1x SFP
Port Types
8x 1G, 2x SFP+
Port Types
10x 1G, 2x SFP
Port Types
10x 1G, 2x SFP+
Port Types
10x 1G, 2x SFP+
Port Types
12x 2.5G, 2x SFP+
Port Types
16x 1G/10G Fiber SFP+
Port Types
26x 1G, 4x SFP
Port Types
26x 1G, 4x SFP
Port Types
40x 1G, 8x SFP
Port Types
40x 1G, 8x SFP+
Port Types
40x 1G, 8x SFP+
Total PoE Budget
Total PoE Budget
480W
Total PoE Budget
110W
Total PoE Budget
220W
Total PoE Budget
125W
Total PoE Budget
240W
Total PoE Budget
720W
Total PoE Budget
Total PoE Budget
Total PoE Budget
300W
Total PoE Budget
1,440W
Total PoE Budget
480W
Total PoE Budget
960W
Total PoE Budget
2,880W
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
8
# PoE+ Ports
8
# PoE+ Ports
8
# PoE+ Ports
8
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
# PoE+ Ports
24
# PoE+ Ports
# PoE+ Ports
40
# PoE+ Ports
40
# PoE+ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
8
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
24
# PoE++ Ports
# PoE++ Ports
# PoE++ Ports
40
Rack Mount
Rack Mount
1U
Rack Mount
Desktop
Rack Mount
Desktop
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
1U
Rack Mount
2U
Form Factor WxHxD (mm)
440 x 43.2 x 400
210 x 40 x 140
210 x 40 x 140
440 x 43.2 x 200
440 x 43.2 x 200
440 x 43.2 x 257
440 x 43.2 x 100
440 x 43.2 x 200
440 x 43.2 x 257
440 x 43.2 x 400
440 x 43.2 x 400
440 x 43.2 x 400
440 x 86.4 x 350
MAXIMIZE
PERFORMANCE
WITH NETGEAR
ACCESS POINTS
Enable powerful, reliable WiFi at your location with WAX600 Series PoE access points.
PRO AV
RESOURCES
m4250-pro-av-10-mb m4250-pro-av-10
Tech Specs - GSM4230PX Front
Tech Specs - GSM4230PX Back
  • Dimensions (WxDxH) : 440 x 400 x 43.2 mm
  • Weight : 5.45 kg (12.02lb)
  • Primary Port Speed : 1 Gigabit
  • Number of Ports : 30 (24x 1G PoE+, 2x 1G, 4x SFP+)
  • PoE Ports / Budget : 24 PoE+ (30W/port), 480W Budget
  • IGMP Support : Enhanced (NETGEAR IGMP Plus™)
  • Jumbo Frame Support : Yes, up to 12kb
  • AVB Support : Yes. Electronic license required, activation key sent via email (AVB4230PX-10000S)
  • Acoustics : Fanless or 42dB@25ºC
  • TBD Power Consumption : With PoE: 614W/2096.2Btu/hr
  • Without PoE: 46.8W/159.78Btu/hr
  • Standby without any port connection: 33.9W/115.73Btu/hr
  • Third party support : Domotz
    • Warranty: This product is backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty . This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
  • Support : Phone and chat technical support provided for 90 days from purchase date.
  • What's in the Box : M4250-26G4XF-PoE+ (GSM4230PX)
  • Power cord(s)
  • Console USB Type-C and RJ45-DB9 cables
  • Rack-mounting standard brackets
  • Longer brackets for recessed mounting
  • Rubber footpads for tabletop installation
  • Installation guide
