M4350-24X4V Fully Managed Switch (XSM4328CV)
24x10G/Multi-Gig PoE+ (576W base, up to 720W) and 4xSFP28 25G (XSM4328CV)
- 24 10G/Multi-Gig PoE+ ports with 4 25GBASE-X SFP28 uplinks
- 880W internal power supply providing 576W of PoE budget
- 1 slot for modular power supply (1+1 redundancy and/or EPS share)
- Any APS350Wv1, APS600Wv2, APS920Wv1, or APS2000Wv1 can be used
- The PoE budget can reach 720W, when the redundant PoE budget remains 576W
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
- TAA compliant SKU is available. Contact your sales representative
![M4350 Power and Throughput](/hk-en/media/m4350-power-and-throughput-mobile_tcm199-150409.webp)
![m4350 Power And Throughput](/hk-en/media/m4350-power-and-throughput_tcm199-150410.webp)
POWER AND
THROUGHPUT
![M4350 AV OVER IP SIMPLIFIED](/hk-en/media/m4350-av-over-ip-simplified-mobile_tcm199-150412.jpg)
![M4350 AV OVER IP SIMPLIFIED](/hk-en/media/m4350-av-over-ip-simplified_tcm199-150411.webp)
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
![M4350 FAST, EASY CONFIGURATION](/hk-en/media/M4350-fast-easy-configuration-mobile_tcm199-150413.webp)
![M4350 FAST, EASY CONFIGURATION](/hk-en/media/M4350-fast-easy-configuration_tcm199-150414.webp)
FAST, EASY
CONFIGURATION
FOR AV PROS
![](/hk-en/media/m4250-pro-av-dt-4-mb_tcm199-139372.jpg)
![](/hk-en/media/m4250-pro-av-dt-4_tcm199-139378.jpg)
FOCUS ON THE EVENT
NOT FAN NOISE
![](/hk-en/media/m4250-pro-av-dt-5-mb_tcm199-139371.jpg)
![](/hk-en/media/m4250-pro-av-dt-5_tcm199-139377.jpg)
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
![]() XSM4328CV |
![]() GSM4328 |
![]() GSM4352 |
![]() MSM4352 |
![]() XSM4316 |
![]() XSM4324 |
![]() XSM4328FV |
![]() XSM4340CV |
![]() XSM4340V |
![]() XSM4340FV |
![]() VSM4320C |
![]() XSM4344C |
# Total Ports |
# Total Ports 28 |
# Total Ports 28 |
# Total Ports 52 |
# Total Ports 52 |
# Total Ports 16 |
# Total Ports 24 |
# Total Ports 28 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 20 |
# Total Ports 44 |
Port Types |
Port Types 24x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G, 4x SFP+ |
Port Types 48x 1G, 4x SFP+ |
Port Types 44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 8x 1G/2.5G/5G/10G, 8x SFP+ |
Port Types 12x 1G/2.5G/5G/10G, 12x SFP+ |
Port Types 24x SFP+, 4x SFP28 (25G) |
Port Types 36x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G) |
Port Types 32x SFP+, 8x SFP28 (25G) |
Port Types 16x SFP28 (25G), 4x QSFP28 (100G) |
Port Types 40x 1G/2.5G/5G/10G, 4x QSFP28 (100G) |
Total PoE Budget |
Total PoE Budget 576W -> 720W |
Total PoE Budget 648W –> 720W |
Total PoE Budget 236W -> 1,440W |
Total PoE Budget 194W -> 3,314W |
Total PoE Budget - |
Total PoE Budget 280W -> 1,760W |
Total PoE Budget 290W -> 1,770W |
Total PoE Budget 196W -> 1,676W |
# PoE+ Ports |
# PoE+ Ports 24 |
# PoE+ Ports 24 |
# PoE+ Ports 48 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE++ Ports |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 48 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 36 |
# PoE++ Ports 24 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 40 |
Rack Mount |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
FORM FACTOR W X H x D (MM) |
FORM FACTOR W X H x D (MM) 440 x 400 x 43.2 |
FORM FACTOR W X H x D (MM) 220 x 400 x 43.2 |
![GSM4352 MAXIMIZE PERFORMANCE](/hk-en/media/M4350_Max_performance_XSM4328CV_mobile_tcm199-150729.webp)
![GSM4352 MAXIMIZE PERFORMANCE](/hk-en/media/M4350_Max_performance_XSM4328CV_desktop_tcm199-150728.webp)
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
![](/hk-en/media/m4250-pro-av-dt-8-mb_tcm199-139370.jpg)
![](/hk-en/media/m4250-pro-av-dt-8_tcm199-139376.jpg)
PRO AV
RESOURCES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
M4350-XSM4328CV Technical Specifications
![XSM4328CV_Tech-Specs-Front](/hk-en/media/XSM4328CV_Tech-Specs-desktopv2_tcm199-150726.jpg)
![XSM4328CV_Tech-Specs-Back](/hk-en/media/XSM4328CV_Tech-Specs-mobilev2_tcm199-150727.jpg)
Product Specifications
M4350-24X4V (XSM4328CV)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight6.58kg (14.51lb)
Primary Port Speed10 Gigabit / Multi-Gig
Number of Ports28 (24 x 10G/Multi-Gig PoE+, 4 x 25G SFP28)
PoE Ports / Budget24 PoE+ (30W/port), 576W Base, up to 720W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 34.7dB@25ºC
Power Consumption
With PoE: 750.1W/2557.84Btu/hr
Without PoE: 119.4W/374.92Btu/hr
Standby without any port connection: 53.6W/168.3Btu/hr
PSU Compatible Models
APS350Wv1
APS600Wv2
APS920Wv1
APS2000Wv1
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
This product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
Pro AV Information
M4350-24X4V Support
AV Resource Center
