M4350-36X4V Fully Managed Switch (XSM4340CV)
36x10G/Multi-Gig PoE++ (280W base, up to 1,760W) and 4xSFP28 25G Managed Switch
- 36 10G/Multi-Gig PoE++ ports with 4 25GBASE-X SFP28 uplinks
- 750W internal power supply providing 280W of PoE budget
- 1 slot for modular power supply (1+1 redundancy and/or EPS share)
- Any APS600Wv3, APS1200Wv2, or APS2000Wv2 can be used
- The PoE budget can reach 1,760W, when the redundant PoE budget remains 280W
- Virtual Chassis stacking provides non-stop forwarding (NSF) and hitless failover
- Layer 3 feature set includes static, policy-based, and dynamic routing
- NETGEAR IGMP Plus™, AV User Interface, and Engage Controller speed up AV installations
- NETGEAR ProSAFE® Limited Lifetime Hardware Warranty
- Lifetime Next Business Day Hardware Replacement
![M4350 Power and Throughput](/hk-en/media/m4350-power-and-throughput-mobile_tcm199-150409.webp)
![m4350 Power And Throughput](/hk-en/media/m4350-power-and-throughput_tcm199-150410.webp)
POWER AND
THROUGHPUT
![M4350 AV OVER IP SIMPLIFIED](/hk-en/media/m4350-av-over-ip-simplified-mobile_tcm199-150412.jpg)
![M4350 AV OVER IP SIMPLIFIED](/hk-en/media/m4350-av-over-ip-simplified_tcm199-150411.webp)
Groundbreaking AV GUI
Multicast in an Instant
Sleek, Quiet Design
Automatic Configuration
![M4350 FAST, EASY CONFIGURATION](/hk-en/media/M4350-fast-easy-configuration-mobile_tcm199-150413.webp)
![M4350 FAST, EASY CONFIGURATION](/hk-en/media/M4350-fast-easy-configuration_tcm199-150414.webp)
FAST, EASY
CONFIGURATION
FOR AV PROS
![](/hk-en/media/m4250-pro-av-dt-4-mb_tcm199-139372.jpg)
![](/hk-en/media/m4250-pro-av-dt-4_tcm199-139378.jpg)
FOCUS ON THE EVENT
NOT FAN NOISE
![](/hk-en/media/m4250-pro-av-dt-5-mb_tcm199-139371.jpg)
![](/hk-en/media/m4250-pro-av-dt-5_tcm199-139377.jpg)
DESIGNED FOR
AV OVER IP
RIGHT OUT OF
THE BOX
COMPARE M4350 SERIES SWITCHES
![]() XSM4340CV |
![]() GSM4328 |
![]() GSM4352 |
![]() MSM4352 |
![]() XSM4316 |
![]() XSM4324 |
![]() XSM4328CV |
![]() XSM4328FV |
![]() XSM4340V |
![]() XSM4340FV |
![]() VSM4320C |
![]() XSM4344C |
# Total Ports |
# Total Ports 40 |
# Total Ports 28 |
# Total Ports 52 |
# Total Ports 52 |
# Total Ports 16 |
# Total Ports 24 |
# Total Ports 28 |
# Total Ports 28 |
# Total Ports 40 |
# Total Ports 40 |
# Total Ports 20 |
# Total Ports 44 |
Port Types |
Port Types 36x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x 1G, 4x SFP+ |
Port Types 48x 1G, 4x SFP+ |
Port Types 44x 1G/2.5G, 4x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 8x 1G/2.5G/5G/10G, 8x SFP+ |
Port Types 12x 1G/2.5G/5G/10G, 12x SFP+ |
Port Types 24x 1G/2.5G/5G/10G, 4x SFP28 (25G) |
Port Types 24x SFP+, 4x SFP28 (25G) |
Port Types 24x 1G/2.5G/5G/10G, 8xSFP+, 8x SFP28 (25G) |
Port Types 32x SFP+, 8x SFP28 (25G) |
Port Types 16x SFP28 (25G), 4x QSFP28 (100G) |
Port Types 40x 1G/2.5G/5G/10G, 4x QSFP28 (100G) |
Total PoE Budget |
Total PoE Budget 280W -> 1,760W |
Total PoE Budget 648W –> 720W |
Total PoE Budget 236W -> 1,440W |
Total PoE Budget 194W -> 3,314W |
Total PoE Budget - |
Total PoE Budget 576W -> 720W |
Total PoE Budget 290W -> 1,770W |
Total PoE Budget 196W -> 1,676W |
# PoE+ Ports |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports 48 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports 24 |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE+ Ports - |
# PoE++ Ports |
# PoE++ Ports 36 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 48 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 24 |
# PoE++ Ports - |
# PoE++ Ports - |
# PoE++ Ports 40 |
Rack Mount |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
Rack Mount 1U |
FORM FACTOR W X H x D (MM) |
FORM FACTOR W X H x D (MM) 440 x 400 x 43.2 |
FORM FACTOR W X H x D (MM) 220 x 400 x 43.2 |
![XSM4340CV MAXIMIZE PERFORMANCE](/hk-en/media/M4350_Max_performance_XSM4340CV_mobile_tcm199-150855.jpg)
![XSM4340CV MAXIMIZE PERFORMANCE](/hk-en/media/M4350_Max_performance_XSM4340CV_desktop_tcm199-150854.jpg)
MAXIMIZE
PERFORMANCE
WITH PRO WIFI
ACCESS POINTS
Enable powerful, reliable WiFi at your location with Pro WiFi access points, powered by PoE or an external power adapter.
![](/hk-en/media/m4250-pro-av-dt-8-mb_tcm199-139370.jpg)
![](/hk-en/media/m4250-pro-av-dt-8_tcm199-139376.jpg)
PRO AV
RESOURCES
PRO AV FAMILY COMPARISON
M4250 SWITCH SERIES |
M4350 SWITCH SERIES |
M4500 SWITCH SERIES |
USE CASE |
USE CASE Access/Edge |
USE CASE Core/Access/Edge |
SWITCH STACKING |
SWITCH STACKING No |
SWITCH STACKING Yes |
SWITCH STACKING No (MLAG) |
PoE CAPABLE |
PoE CAPABLE Yes |
PoE CAPABLE Yes |
PoE CAPABLE No |
PORT SPEEDS |
PORT SPEEDS 1, 2.5, 10Gbps |
PORT SPEEDS 1, 2.5, 10, 25, 100Gbps |
PORT SPEEDS 1, 10, 25, 100Gbps |
AVB SUPPORT |
AVB SUPPORT Yes* |
AVB SUPPORT Yes |
AVB SUPPORT No |
AV WEB UI / AV TEMPLATES |
AV WEB UI / AV TEMPLATES Yes |
AV WEB UI / AV TEMPLATES No |
AV DESIGN
AV DESIGN
AV DESIGN
AV DESIGN
M4350-XSM4340CV Technical Specifications
![XSM4340CV_Tech-Specs-Front](/hk-en/media/XSM4340CV_Tech-Specs-desktop_tcm199-150852.jpg)
![XSM4340CV_Tech-Specs-Back](/hk-en/media/XSM4340CV_Tech-Specs-mobile_tcm199-150853.jpg)
Product Specifications
M4350-36X4V (XSM4340CV)1
Power cord(s)1
Console USB Type-C cable1
Rack-mounting standard bracket set1
Set of longer brackets for recessed mounting1
Rubber footpads for tabletop installation4
Installation guide1
Width440mm
Depth400mm
Height43.2mm
Weight7.33kg (16.16lb)
Primary Port Speed10 Gigabit / Multi-Gig
Number of Ports40 (36 x 10G/Multi-Gig PoE++, 4 x 25G SFP28)
PoE Ports / Budget36 PoE++ (90W/port), 280W Base, up to 1,760W Budget
IGMP SupportEnhanced (NETGEAR IGMP Plus™)
Jumbo Frame SupportYes, up to 12kb
AVB SupportYes, included
AcousticsQuiet Mode 32.1dB@25ºC
Power Consumption
With PoE: 454W/1548.14Btu/hr
Without PoE: 148W/464.72Btu/hr
Standby without any port connection: 59.3W/186.2Btu/hr
PSU Compatible Models
APS600Wv3
APS1200Wv2
APS2000Wv2
NETGEAR Engage Controller
Centralized application to configure all switches across your entire network. Lightweight and portable, you can run it from a USB thumb drive.
This product is backed by a NETGEAR ProSAFE® Limited Lifetime Hardware Warranty. Phone and chat technical support provided for 90 days from purchase date. This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/registration within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
Pro AV Information
M4350-36X4V Support
AV Resource Center
