Gigabit Ethernet Unmanaged Switches (GS108MX)
8-Port Gigabit Ethernet Unmanaged Switch with 1 dedicated 10G/Multi-Gig Port
- 8 x Gigabit Ethernet ports
- 1 x 10G/Multi-Gig port
- Energy Efficient Ethernet for maximum power savings
- Fanless and silent
- Desktop or wall-mount
PLUG-AND-PLAY
Simple set up with no software to install or configuration needed
FULL PERFORMANCE
Non-blocking switching architecture for maximum throughput at wire speedSILENT OPERATION
The fanless design means zero added noise wherever its located, making it ideal for noise-sensitive environmentsENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operateMETAL CASE
Durable and rugged case for long-lasting performanceVERSATILE MOUNTING OPTIONS
Supports desktop and wall placement with included wall-mount kitTechnical Specifications
![Desktop_GS108MX](/hk-en/media/Desktop_GS108MX_tcm199-157094.webp)
![Mobile_GS108MX](/hk-en/media/Mobile_GS108MX_tcm199-157093.webp)
NETGEAR GS108MX Unmanaged Switch
Power adapter (varies by region)
Wall-mount kit
Installation guide
Rubber feet
Width236mm (9.3in)
Depth101mm (4.0in)
Height27mm (1.1in)
Weight1.26lb (0.58kg)
Gigabit copper ports8
Uplink port1 x 10G/Multi-Gig Port
Max MAC entries16K
Buffer size768Kbit or 0.75Mbit
EEEYes
Internal/External Power Supply/AdapterExternal Power Adapter
Max power consumption (worst case. all ports used, line-rate traffic)5.8W
Fans0
Acoustic Noise Level @25C0 dBA
Operating Temperature0° to 40° C (32° to 104°F)
MTBF3,514,690 hrs (401 yrs)
Backed by a NETGEAR ProSAFE ® Limited Lifetime Hardware Warranty.
*This product comes with a limited warranty that is valid only if purchased from a NETGEAR authorized reseller, and covers unmodified hardware, fans and internal power supplies – not software or external power supplies, and requires product registration at https://www.netgear.com/business/services/why-register/ within 90 days of purchase; see https://www.netgear.com/about/warranty for details. Intended for indoor use only.
