Gigabit 8-port 300 Series SOHO Unmanaged Switch (GS308V3)
8 Port Gigabit Ethernet Switch Unmanaged GS308
NETGEAR 300 Switch Series featuring 8 ports of gigabit ethernet. This SOHO switch is plug-and-play with unmanaged ports needing no additional configuration at full non-blocking performance. This is the latest V3 model of the GS308 unmanaged switch.
ETHERNET PORT CONFIGURATION
8 Gigabit portsPLUG-AND-PLAY
Simple set up with no software to install or configuration needed and zero maintenanceFULL PERFORMANCE
Non-blocking switching architecture for maximum throughput at wire speedSILENT OPERATION
The fanless design means zero added noise wherever its located, making it ideal for noise-sensitive environmentsENERGY EFFICIENT
Designed to optimize power usage lowering its cost to operate.Metal Case
Durable and RuggedVERSATILE MOUNTING OPTIONS
Supports desktop and wall placement, and includes all mounting hardware in the boxSTANDARDS-BASED DESIGN
Ensure interoperability with any standards-based PDsPlug-and-play
Automatic connectivity to your router or modem of 4 or 7 additional wired connections. No need for an IT expert!Mounting flexibility
Small and silent desktop or rackmount form factor for quiet operation – Adapts to your needs and configuration in any environmentIndustry leading support
ProSAFE LIFETIME Warranty, Next Business Day replacement and 24/7 chat with a NETGEAR expertEnergy efficient
Switches automatically adjust power consumption according to the link status and cable length.Technical Specifications
![gs308v3_tech_specs_image_1](/hk-en/media/gs308v3_tech_specs_image_1_tcm199-99613.png)
![gs308v3_tech_specs_image_2](/hk-en/media/gs308v3_tech_specs_image_2_tcm199-99591.png)
- Dimensions : 158 x 101 x 29mm (6.2 x 4.0 x 1.1in)
- Weight : 0.39 kg (0.86 lb)
- Product name : NETGEAR 8-Port Gigabit Ethernet Unmanaged Switch (GS308V3)
- Speed : Gigabit
- Number of Ports : 8
- PoE budget : N/A
- Energy Efficient Ethernet support : Yes - Compliant with IEEE802.3az Energy Efficient Ethernet mode
- Jumbo frame support : 9,216 bytes
- MAC table size : 4K
- Packet buffer size : 192k
- PoE Auto balance : N/A
- Protocols : IEEE 802.3ab 1000BASE-T Gigabit Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
- IEEE 802.3i 10BASE-T Ethernet
- IEEE 802.3x Flow Control
- IEEE 802.1p Priority QoS (all models)
- IEEE 802.3 CSMA/CD
- 802.3az Energy Efficient Ethernet
