300 Series SOHO Unmanaged Switch (GS316)
16-Port Gigabit Ethernet Unmanaged Switch
Get networks up and running with plug-and-play unmanaged switches. Set it and forget it, energy-efficient switches are built like tanks and last for decades.
Extended Features
PLUG & PLAY: Simple setup with no software or configuration needed.
FLEXIBLE MOUNTING: Mount on desktop or wall.
SMALL SIZE, METAL CASE, AND SILENT OPERATION: Durable quality, space saver, and quietness for peace of mind.
LIFETIME LIMITED WARRANTY & NEXT BUSINESS DAY REPLACEMENT: NETGEAR has your back to ensure your network is up and running.
STURDY METAL CASE, DESKTOP/WALL FORM FACTOR WITH QUIET FANS: Can be placed on desk or on mounted the wall and will operate quietly with assured durability.
Choice of Fast Ethernet and Gigabit Ethernet connectivity
Energy-efficient technology for power savings
Auto-MDI/MDIX eliminates the need for crossover cables
Auto-negotiation for automatic connection at the highest common speed between switch and an end device
Desktop, wall or rackmountable
The NETGEAR Gigabit Unmanaged Switch series helps businesses cost-effectively expand their network to Gigabit speeds and higher port counts
Unmanaged Gigabit switches come in a wide range of models including desktop, wall-mount and rackmount form factors and 5 to 24 port configurations
Energy efficient, built to last, and rigorously tested to provide the reliability businesses need
802.1p traffic prioritization and jumbo frame support allow for seamless integration with more sophisticated networks
![GS316_tech_specs_image_1](/hk-en/media/GS316_tech_specs_image_1_tcm199-99627.png)
![GS316_tech_specs_image_2](/hk-en/media/GS316_tech_specs_image_2_tcm199-99642.png)
- Dimensions (W x D x H) : 286 x 101 x 26 mm (11.3 x 4.0 x 1.0 in)
- Weight : 0.84 kg (1.86 lb)
- Management Type (if applicable) : Unmanaged
- Speed : Gigabit
- Number of Ports : 16
- PoE ports/Max power output : N/A
- Energy Efficient Ethernet Support : Yes
- Jumbo Frame Support : 9,216 bytes
- Packet buffer size : 1 MB
- Power Supply : External
- PoE Auto balance : N/A
- PoE budget : NA
