How to Reset Your NETGEAR Router Password
NETGEAR Logo White Black Background
WRITTEN BY
NETGEAR Team
Have you ever forgotten your NETGEAR router password and had trouble accessing your home network? Or have you ever wanted to change your password to something more secure and memorable? If you answered yes to either of these questions, then this article is for you.
Why Does Resetting the NETGEAR Password Matter?
In this article, you will learn how to reset your NETGEAR router password using the password recovery feature, and why password security is important for protecting your online accounts and devices. In the digital age, securing your home network is as crucial as locking your front door. One key security aspect is your NETGEAR router password. Whether you’ve forgotten it or wish to upgrade it, understanding how to reset your NETGEAR router password is essential. We can guide you through the password reset process for robust password security.
If you have forgotten your NETGEAR router password, you can use the password recovery feature to restore it. You can access this feature by answering security questions you have previously set up. Here are six steps to follow when resetting your NETGEAR router password.
  1. Step 1. Connect to Your Router: Establish an Ethernet cable or WiFi connection to your router and your computer or other device. See the Router Login article page for more information.
  2. Step 2. Navigate to Router Login: Open your web browser and visit routerlogin.net or routerlogin.com.
  3. Step 3. Initiate Password Recovery: From the Login window, you should be able to access the Router Password Recovery window.
  4. Step 4. Serial Number Entry: Locate and enter the serial number found on the back of the router or the underside.
  5. Step 5. Security Questions: You will need to answer the pre-arranged security questions.
  6. Step 6. Retrieve Your Password: Click ‘Continue’, and your admin password will be displayed.
Note: If password recovery isn’t enabled on your device, or you can’t answer the security questions, a factory reset may be necessary. A factory reset returns all your settings to the factory default settings, including the default password and default username. For factory reset instructions, refer to the NETGEAR Support Page.
nighthawk rs700s speed security ad
The Critical Role of Password Security
In today’s interconnected world, WiFi password security is more than just a convenience; it’s a necessity. The critical role of password security with WiFi router settings and wired connections includes:
  • Shielding personal and financial information as the first line of defense against unauthorized access.
  • Thwarting attacks where one compromised password can endanger multiple accounts.
  • Fortifying home network security and safeguarding your network name.
Best Practices for Password Security
Craft strong and unique passwords that are distinct for your accounts. You can use a password manager for secure storage and management of your passwords. Consider changing your passwords periodically, particularly if you are concerned about potential data breaches. Implement multi-factor authentication to add an extra step beyond just the password.
By understanding password security, you can significantly bolster your home network with safeguards against potential cyber threats. Resetting your NETGEAR router password will help you regain access to your digital life. By embracing robust password practices, you can ensure a safer and more secure online experience. Visit the NETGEAR Knowledge Base for more information and inspiration.
Why Password Security Matters
Password security is important because it protects your online accounts, devices, and internet connection from cyberattacks. A weak or compromised password can expose your personal information, router firmware settings, IP address, financial data, and online activities to hackers, who can use them for malicious purposes.
The average person in America uses the same password for multiple accounts. This means that a hacker can access many accounts using the same password. This is a very common type of attack among cybercriminals. You should also avoid sharing your passwords with anyone and avoid using public or unsecured WiFi networks to access your accounts, as they can be easily intercepted by hackers.
NETGEAR Armor For Enhanced Router Security
NETGEAR Armor SecurityA strong Router password is an important front-line defense for your home cybersecurity, but did you know that unsecure Internet of Things (IOT) devices and unsecured hardware can be a security risk regardless of a strong router password?
For even more protection consider NETGEAR Armor – essential all-in-one internet security
available exclusively on Orbi Mesh WiFi systems and Nighthawk routers. NETGEAR Armor keeps your family and your connected devices safe with an automatic shield of protection for your network to stop hackers, password thieves, ransomware, and brute force attacks.
Video: NETGEAR Router Password Reset and Recovery
