How to Extend WiFi Coverage: The Ultimate Troubleshooting Guide
Modern homes in the United States are filled with obstructions like solid walls, concrete, and metal that can interfere with your WiFi signal. Your internet isn’t broken — it’s a matter of physics vs. your router, and there are simple solutions to get your connection back on track.
Learn more about How to extend your home WiFi range in the short video below:
Why Home WiFi Slows Down
Does your WiFi performance struggle with poor coverage, such as dead zones, slow speeds in specific rooms, or dropped connections? Do you want to boost the WiFi signal through walls? You are not alone. These are common issues usually caused by distance and interference. Key factors that can affect WiFi home network performance include:
Physical & Environmental Factors
Distance from the router: WiFi signals weaken the farther you are from the access point.
Obstructions: Concrete, brick, and other solid barriers can significantly weaken wireless signals.
Router placement: Routers placed in low positions, corners, or inside cabinets reduce overall coverage.
Wireless Interference
Other WiFi networks: Neighbors’ routers on the same channel can cause congestion and interfere with WiFi performance.
Household devices: Microwaves, Bluetooth devices, baby monitors, and other gadgets can interfere with the 2.4GHz WiFi bandwidth.
Network Load & Congestion
Too many devices: Phones, laptops, TVs, and smart home IoT devices all share bandwidth, which can overwhelm older hardware.
High-bandwidth activities: 4K streaming, gaming, and video calls can quickly saturate slower WiFi connections.
Hardware & Configuration Issues
Old routers: Older standards like WiFi 5 can’t handle modern speeds or many devices in concurrent use.
Outdated firmware: Using the wrong channel or outdated firmware can hurt wireless network performance.
Infrastructure problems: Faulty Ethernet cables and weak WiFi extenders can degrade performance.
Catch-All NETGEAR WiFi Solutions
There are several ways to counter obstacles and signal degradation to achieve much better WiFi performance, and NETGEAR has the best options available for every home size.
WiFi Extenders
WiFi extenders (boosters/repeaters) are useful when you want to eliminate a specific WiFi dead zone or improve coverage in a single extra room. They’re generally affordable and easy to plug in. However, you may need a separate SSID network name to connect, and the signal beyond the extender may degrade. Nighthawk WiFi extenders are designed to work with any WiFi router, including ISP-provided equipment.
WiFi Mesh Systems
NETGEAR WiFi mesh, such as the Orbi 970 Series Mesh WiFi 7 System, is changing how home networks operate. These systems include a main WiFi 7 router and multiple mesh extender satellites that communicate to automatically hand your connection to the strongest signal without drops.
WiFi mesh is ideal for large and multi-level homes. To set up your Orbi Mesh Router, simply connect it to your modem and place satellites strategically around your home. This provides seamless WiFi coverage upstairs, downstairs, and even into the backyard. Mesh WiFi is the superior solution with dedicated backhaul, a single SSID for seamless roaming, and high-speed capacity.
For medium-sized homes, the perfect middle ground is a powerful standalone router like the Nighthawk RS700S WiFi 7 Router. This state-of-the-art router can achieve speeds up to 19Gbps and cover up to 3,500 sq. ft. for up to 200 concurrent devices.
Since the 1990s, NETGEAR has pioneered WiFi technology to amplify signal strength for all connected devices. Premium features include:
Tri-Band & Quad-Band WiFi: Cutting-edge “fast lane” technologies that prevent congestion across 2.4GHz, 5GHz, and 6GHz bands.
WiFi 7: Offers a 2.4x speed increase over WiFi 6, using Multi-Link Operation (MLO) to block interference and increase speeds.
Advanced Antenna Design: Optimized for 360° coverage with beamforming to target dedicated devices.
NETGEAR Armor Security: Powered by Bitdefender, providing automatic firmware updates, VPN, and WPA3 encryption.
WiFi for Today’s Connected Homes
A strong, reliable WiFi connection is essential for the modern home. Understanding the causes of dead zones allows you to make informed decisions—whether you are optimizing your current setup or upgrading to solutions like Orbi Mesh. Choosing the right approach means streaming, gaming, and working anywhere you want, without interruption.
Ready to banish dead zones forever? Find the perfect Orbi Mesh System for your home.
FAQs
Why is my WiFi slow in the bedroom?
WiFi signals degrade as they pass through dense walls and travel over distance. A WiFi extender or mesh system can eliminate these dead zones, ensuring stable connectivity for both work and play in every room.
Does moving my router higher improve speed?
Yes. Radio waves travel down and out; the floor is the worst place for a router. Elevating your router on a table or shelf in a central location delivers optimal performance and much better wireless coverage.
Why is my WiFi router slowing down?
WiFi technology is rapidly advancing. If your system is struggling with 4K/8K streaming or extensive smart home networks, it’s likely time to upgrade to a NETGEAR WiFi 7 router or a whole-home mesh system.
