Mobile Router vs. Public Hotspots for Security
5G mobile hotspot routers have come a long way compared to earlier hotspots, including features such as the addition of state-of-the-art enhanced and encrypted security for all devices in connected WiFi networks. Leading portable hotspots are the safe and seamless alternative to public hotspots for 24/7 connectivity, wherever your travels take you.
Arodi Dalpathadu
WRITTEN BY
Arodi Dalpathadu,
Sr. Product Line Manager,
CHP
Secure Your Digital Life: The Superior Security of 5G Mobile Routers Over Public WiFi
Enhanced 5G security of mobile hotspots is a major advantage compared to phone tethering or public WiFi in cafes, hotel foyers, and libraries. With a NETGEAR Nighthawk Mobile Router, you can still set up your WiFi network in your favourite cafe, but without the risk of malicious network intrusions or other people trying to connect using your mobile data.
Quality mobile WiFi routers have a powerful battery for all-day device use, and you can also connect using an AC power adapter. With unlocked mobile WiFi, you get to choose your SIM card and provider options for limited data, unlimited data, and pay-as-you-go plans. The addition of an optional external omnidirectional antenna will help establish an even stronger connection.
The Hidden Dangers of Public WiFi Security
If you feel uneasy when using public WiFi, you are not alone. Although most public WiFi is relatively safe and convenient to use in a pinch, it has its limitations, along with the potential for security vulnerabilities.
Here are some hidden dangers of public WiFi worth knowing about.
Man-in-the-middle (MITM) attacks where a person eavesdrops on your communication. Unencrypted networks and a lack of security features. Malware distribution with the risk of downloading malicious software. WiFi snooping to get unauthorized data. Malicious hotspots and fake WiFi networks set up by hackers.
In today’s digital world, protecting your personal information is crucial. Virtual Private Networks (VPNs) help by encrypting your data and masking your online activity, making it much harder for anyone to intercept your information.
However, a VPN isn’t a magic shield. It secures your connection and hides your IP address, but your device is still connected to the public network, meaning it’s visible to others. That’s why it’s important to use strong passwords, keep your software updated, and be cautious online.
While VPNs are valuable for enhancing privacy, they should be part of a broader security strategy. Use them alongside other tools and smart practices to stay safe online.
Understanding 5G Mobile Router Security
5G mobile internet is slowly spreading around America and the world, and with it comes incredibly fast internet speeds. 5G internet is so fast that multi-gigabit data rates are a reality for high-bandwidth activities. Naturally, 5G also delivers security enhancements for keeping mobile networks safe.
As a growing number of devices come equipped with 5G technology, the full benefits of the latest portable routers such as the NETGEAR Nighthawk M6 Pro are on show. Here are some major Nighthawk 5G security advantages compared to public WiFi.
Authentication – 5G networks use strong authentication protocols, building upon the security features of 4G LTE. Encryption – When you connect to a 5G network using a mobile hotspot, it encrypts your identifying device and network information. Low Latency – 5G’s low latency maximizes data rates, enhancing the ability of security to monitor and respond in real-time. Massive Capacity – 5G mobile routers from NETGEAR can handle multiple devices connected simultaneously without compromising security. Ultra-Wideband – The ultra-wide 5G bandwidth provides speeds up to ten times faster than 4G LTE WiFi for better overall device performance and security.
Data Encryption: Your First Line of Defense
5G mobile (portable) hotspots are internet hubs that can convert a 5G connection into an ultra-fast wireless signal for phones, laptops, or anything else that needs to be connected to the internet. Data encryption is the first line of defense to keep everything protected while you are online.
Data encryption is the process of transferring data from a readable format into a cryptic format to protect the data’s integrity and security. Encryption keeps other people from accessing your sensitive information while it is being transmitted online. With NETGEAR Nighthawk M6 and M6 Pro mobile routers, only authorized parties with the correct encryption key can gain access to the information.
The average American home of today can have dozens of WiFi devices and smart home applications connected simultaneously, and connectivity is equally important for people on the move. In fact, some smart home devices can be operated remotely with a mobile hotspot router. It’s all about convenience in a connected world with the best Nighthawk mobile hotspots.
The Benefits of Using Your Own Mobile Hotspot
Advances in WiFi technology have elevated leading mobile hotspots to the next level of performance. The Nighthawk M6 Pro is among the most capable 5G hotspots on the market, and one of the few hotspots equipped to handle mmWave speeds. The M6 Pro has a 2.5Gbps Ethernet port, 6GHz WiFi support, and even external antenna ports.
In a nutshell:
Support for 5G bands including mmWave Fast 2.5Gbps Ethernet built-in AXE3600 dual-band WiFi 6E capabilities State of the art encryption and authentication protocols Large 5040mAh battery TS-9 antenna ports
The Nighthawk M6 Pro is the fastest and most capable mobile hotspot from every angle. It includes the latest Qualcomm SDX65 chipset for incredible 5G speeds and support for a large number of 5GNR bands, including mid-band and mmWave. M6 Pro is easy to set up using the handy Nighthawk app, including enhanced and encrypted security for protection from cyber threats.
The Limitations of Mobile Hotspots
Data usage, battery life, and coverage are common concerns with people considering mobile hotspot devices. Earlier WiFi hotspot devices performed well, but technology has moved on and 5G mobile hotspots have mitigated most concerns. Coverage is improved with the additional bandwidth and capabilities, while unlocked hotspots with your choice of SIM card and data plan are the way to go for people who travel often for business or pleasure.
It’s also worth considering purchasing a second battery. Nighthawk M6 Pro batteries last for up to 13 hours of device use, and a second battery will ensure 24/7 WiFi access wherever you are.
Making the Switch: Why Your Own Mobile Hotspot is Safer Than Public WiFi
Public WiFi networks and free WiFi were a revelation when they were first introduced. However, they have always struggled to provide the connection quality, speeds, and security enhancements that users demand. Today, mobile WiFi is used in a wide range of industries, from first responders needing best quality communications devices, to creators and influencers broadcasting updates on the go. Here are some sectors where WiFi plays an essential role:
Manufacturing
Automated manufacturing robots rely on mobile WiFi for communication. Inventory scanners benefit from WiFi for tracking. Unmanned factory machinery and vehicles rely on WiFi for navigation and data exchange.
Healthcare
Hospitals utilize mobile WiFi for electronic health records and file sharing, while telemedicine services depend on reliable WiFi. Some medical devices connect via mobile WiFi for data transmission. Hospitals and other healthcare services require a strongly secured network to protect patient information at remote clinics or on-the-go.
Retail and Hospitality
Many restaurants and stores use contactless mobile WiFi for processing orders and deliveries. Some hotels and cafes offer public WiFi hotspots to guests for convenience, although an unsecured network runs the risk of exposing personal data, sensitive data, online accounts, or bank accounts on the internet. Savvy travelers carry their own mobile hotspot router that can be safely set up with encrypted security in a cafe, hotel lobby, or anywhere else within WiFi cell tower range.
Transportation and Logistics
Airlines and other passenger-travel industries rely on mobile technology for a range of passenger services. Mobile WiFi is also used by logistics companies for tracking shipments and managing inventory.
Education
WiFi is used in schools and universities for online learning, remote learning, research, and study. Many libraries offer WiFi access to students and visitors. The number of applications is growing annually.
Construction and Field Services
Mobile WiFi is used for general communication, safety, and project management, both on-site and remotely. Service persons and field technicians rely on wireless mobile connectivity for real-time updates and troubleshooting.
Entertainment
Many concert venues, sports stadiums, and festivals provide WiFi for people who attend. Entertainment streaming services are reliant on the rollout of blazing-fast mobile WiFi for high-definition content delivery.
How NETGEAR’s 5G Mobile Routers Elevate Your Security
NETGEAR 5G security capabilities automatically protect all users in your mobile network from man-in-the-middle attacks, and malware that can otherwise corrupt device operating systems. NETGEAR 5G Mobile Routers feature lots of technology improvements, with a strong focus on security. Features to look for in this portable firewall router is URL filtering, MAC address filtering, pass code lock, 5G cellular encryption, and WPA3 WiFi encryption.
NETGEAR Nighthawk M6 and M6 Pro Mobile Routers are the safe and secure way to enjoy networking, social media blogging, gaming, and anything else requiring online security for a protected and seamless internet connection. Unsecured WiFi is unthinkable in today’s connected world, making robust security a must-have for both home networks and mobile WiFi networks. For some of us, NETGEAR 5G mobile WiFi is used for home WiFi and for a fast, reliable and secure WiFi access point when we are on the road, working remotely, or traveling overseas for business or pleasure.
Step into a Safer Digital World with NETGEAR
Online security should be a public WiFi top priority, so NETGEAR introduces WiFi users to a safer digital world. NETGEAR has been a WiFi leader and innovator since the 1990s, and the tradition continues with the latest industry-leading 5G mobile routers for people on the go.
You have a right to keep personal details and important information private while browsing Windows and networking online. It’s no different in public WiFi spaces where security risks are a reality. Fortunately, groundbreaking 5G WiFi means cybersecurity risks from malicious WiFi users can be mitigated in real time. The first step is to consider your digital life when choosing how to connect to the internet, and NETGEAR Nighthawk 5G Mobile Routers make perfect sense.
