Introducing Nighthawk M7 Pro MR7400 for AT&T
We are excited to introduce the first of its kind Nighthawk M7 Pro with WiFi 7 technology.
This new WiFi standard powers data-intensive applications by utilizing multi-link operation (MLO support coming soon), 4K QAM, and 320MHz bandwidth for faster speeds with seamless throughput. The Nighthawk M7 Pro MR7400 for AT&T is the most progressive hotspot router on the planet, offering up to 2,000 sq. ft. coverage for up to 64 devices in concurrent use. The M7 Pro can replace your home router and accompany you when you are on the road or away on business.
5G WiFi 7 Mobile Hotspot for AT&T Powered by Nighthawk Mobile
WiFi routers have evolved from WiFi 5 and battery-sapping smartphone WiFi. Today’s best mobile hotspot WiFi devices can deliver fast downloads, low latency, enhanced security, and multi-gigabit speeds for streamers, gamers, and remote workers. The Pro 7 MR7400 offers up to 13 hours of continuous battery life. For a guaranteed connection 24/7, carry a spare battery with you. A mobile hotspot is more powerful, secure, and long-lasting than Apple or Android cellular phone tethering. The Nighthawk M7 Pro is the world’s first WiFi 7 5G hotspot, a new wireless network performer worth owning.
Main MR7400 Features and Benefits
The MR7400 WiFi 7 mobile hotspot router is more advanced and capable than tri-band WiFi 6E and WiFi 6 routers. There are dozens of MR7400 features and benefits worth knowing about.
Standout M7 Pro features include:
- Combination of 5G carrier aggregation and WiFi 7 technology
- Up to 2,000 sq. ft. of strong WiFi coverage
- 13 hours of battery life
- WiFi Performance up to 5.8 Gbps
- Roaming in up to 125 countries
- Ethernet up to 2.5Ghz, USB tethering at up to 10Gbps (USB-C to Ethernet support coming soon)
- WiFi 7 Technology on 2.4Ghz, 5Ghz and 6Ghz bands
- Mobile security to block unwanted content and protect your family
What is WiFi 7 technology?
WiFi 7, also known as IEEE 802.11b, is the latest generation and new standard of WiFi technology approved by the WiFi Alliance. WiFi 7 technology includes MU-MIMO, 320 MHz channels, OFDMA, 4K QAM (up from 1024 QAM), Preamble Puncturing, dedicated backhaul, and more. WiFi 7 supports wireless connectivity on the 2.4GHz band, 5GHz band, and 6GHz band. The latest WiFi 7 Nighthawk mobile hotspots are compatible with any internet service provider, and WiFi 7 is backward compatible with earlier WiFi versions.
Top WiFi 7 Mobile Hotspot Use-Cases for Consumers
Several advantages make super-flexible NETGEAR Nighthawk M7 Pro a game changer.
Power your entire home’s WiFi or take WiFi on the go.
- This mobile hotspot is small enough to fit in a pocket or purse, yet powerful enough for robust laptop, iPad, and smartphone performance while on the go.
- You can establish a secure WiFi network for family, friends, or colleagues locally, nationally, or internationally.
- Use for video streaming, gaming, and next-generation smart home devices.
- Replace poor wired ISP plan options plans with even coverage in your home with high-speed wireless connectivity.
- Unlock a powerful WiFi connection anywhere or plugin and remove the battery for extreme in-home performance.
- Use the M7 Pro MR7400 as a modem or connect to a mesh system.
- Increase coverage with an Omnidirectional MIMO Antenna.
Hotspot Use Cases for Business Customers
Businesses are more mobile than ever, requiring mobile hotspot routers with responsiveness to adapt on the go. Fortify your business with secure 5G & WiFi 7.
Nighthawk M7 Pro blankets your devices with encrypted AT&T 5G and next-gen WiFi 7 for seamless, worry-free collaboration across 64 devices.
- Powerful and secure WiFi anywhere your business takes you.
- Share secure WiFi with colleagues and clients.
- Ideal for temporary construction works and mobile offices.
- Keep in touch during business trips and conferences.
- Work from home or in shared locations with a strong and secure connection.
More Nighthawk M7 Pro Attributes
Nighthawk M7 Pro brings secure WiFi everywhere with best-in-class 5G technology that supports current and future 5G Sub-6 connections.
Here are some more M7 Pro specs and features.
- Use the 2.8” color LCD touchscreen to change settings, monitor usage, and access the powerful web interface for advanced configuration.
- Set up and manage on the device or on the web.
- Qualcomm Snapdragon® X75 5G Modem-RF System.
- Block unwanted content or devices and protect your family with built-in URL filtering and device blocking.
- Surf with confidence and safeguard your devices from online threats.
- Options for WiFi, Ethernet, or USB tethering.
- Supports business customers with Insight Pro to remotely manage, deploy, and configure enterprise mobile hotspot devices with complete visibility.
Choosing NETGEAR Nighthawk M7 Pro
A NETGEAR Nighthawk M7 Pro mobile router can broadcast a Guest WiFi SSID, allowing others to use your device connection safely and securely. You can generate a new password for each guest who connects. M7 Pro also supports WiFi Ethernet offloading (feature coming soon) that saves hotspot device data use while you are traveling away from home. If you want faster Gbps data rates, high throughput, lower latency, and compatibility with existing network devices, a Nighthawk M7 Pro MR7400 mobile hotspot with AT&T is the answer.
The NETGEAR Nighthawk M7 Pro MR7400 is available in the US from AT&T and major mobile retailers.
